checking valve timing?
From vic
ok so tomorrow i am going to remove the timing cover to check my cam timing due to my off idle hesitation and sluggishness that is carried on from 4 different carburettors so i can conclude the carburettors are fine.
so when i open up the cover what should i look for i know theres a mark on the cam and crank sprockets but how should they be lining up at TDC 1 and how can i tell if the cam timing is right or incorrect?
Thanks!
Posted on: 2011/12/15 7:59
Subject Poster Date
     checking valve timing? a12datto120y 2011/12/15 7:59
       Re: checking valve timing? ddgonzal 2011/12/15 8:44
         Re: checking valve timing? a12datto120y 2011/12/15 8:53
         Re: checking valve timing? ddgonzal 2011/12/15 8:55
       Re: checking valve timing? a12datto120y 2011/12/15 9:00
         Re: checking valve timing? 1200rallycar 2011/12/15 11:05
       Re: checking valve timing? a12datto120y 2011/12/16 3:06
         Re: checking valve timing? ddgonzal 2011/12/16 3:27
       Re: checking valve timing? a12datto120y 2011/12/16 5:09
       Re: checking valve timing? bige 2011/12/16 5:25
         Re: checking valve timing? a12datto120y 2011/12/16 5:30
       Re: checking valve timing? bige 2011/12/16 5:31
         Re: checking valve timing? a12datto120y 2011/12/16 5:32
       Re: checking valve timing? bige 2011/12/16 5:33
         Re: checking valve timing? a12datto120y 2011/12/16 5:34
       Re: checking valve timing? bige 2011/12/16 5:35
       Re: checking valve timing? a12datto120y 2011/12/16 5:40
       Re: checking valve timing? ddgonzal 2011/12/16 5:52
