Re: Ackkk......I've turned into Colin Chapman.........sort of.
From brisbane
Have you already done the easy and free options like removing the spare tyre, tool kit, jack, passenger seats, factory seat belts, trim panels, roof lining etc?
What about cheap options like removing all sound deadening, cutting out all unused brackets, swiss cheesing the remaining brackets, cutting the excess length off all bolts and screws, removing the dash and using a a small alloy panel for the gauges and warning lights, cutting out the spare wheel well and covering the hole with an alloy panel, fitting lexan side and rear windows?
Posted on: 2011/12/25 2:04
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Subject Poster Date
     Ackkk......I've turned into Colin Chapman.........sort of. Rallytwit 2011/12/23 21:09
       Re: Ackkk......I've turned into Colin Chapman.........sort of. ddgonzal 2011/12/23 23:19
         Re: Ackkk......I've turned into Colin Chapman.........sort of. Wombat_racing 2011/12/23 23:43
           Re: Ackkk......I've turned into Colin Chapman.........sort of. D 2011/12/24 0:20
             Re: Ackkk......I've turned into Colin Chapman.........sort of. demacoz 2011/12/24 2:55
               Re: Ackkk......I've turned into Colin Chapman.........sort of. LittleFireyOne 2011/12/24 6:06
               Re: Ackkk......I've turned into Colin Chapman.........sort of. matty 2011/12/25 1:50
                 Re: Ackkk......I've turned into Colin Chapman.........sort of. matty 2011/12/25 2:04
                   Re: Ackkk......I've turned into Colin Chapman.........sort of. Wombat_racing 2011/12/25 9:09
                     Re: Ackkk......I've turned into Colin Chapman.........sort of. matty 2011/12/25 11:10
                       Re: Ackkk......I've turned into Colin Chapman.........sort of. Anonymous 2011/12/25 11:13
                         Re: Ackkk......I've turned into Colin Chapman.........sort of. D 2011/12/25 13:44
             Re: Ackkk......I've turned into Colin Chapman.........sort of. D 2011/12/25 0:08
       Re: Ackkk......I've turned into Colin Chapman.........sort of. Rallytwit 2011/12/29 2:20
         Re: Ackkk......I've turned into Colin Chapman.........sort of. D 2011/12/29 4:36
           Re: Ackkk......I've turned into Colin Chapman.........sort of. matty 2011/12/29 7:52
