Re: Flywheel bolts failure\fix\questions
Good to hear that balancing the engine and loctite/doweling the flywheel is the go
What are the clutch vibration symptoms? For example does it only do it with the clutch pedal down? Does it do it on the road, or when revving in neutral?
Posted on: 2016/1/9 3:58
Subject Poster Date
     Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/4 7:45
       Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/4 8:08
         Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/4 8:24
           Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/4 10:29
       Re: Flywheel bolts failure\fix\questions A14force 2012/1/4 8:52
       Re: Flywheel bolts failure\fix\questions Lemonhead 2012/1/4 8:53
       Re: Flywheel bolts failure\fix\questions BigV 2012/1/4 10:05
       Re: Flywheel bolts failure\fix\questions Rusty-Wrench 2012/1/5 7:05
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/6 10:54
         Re: Flywheel bolts failure\fix\questions racer135 2012/1/6 15:37
       Re: Flywheel bolts failure\fix\questions Dion120Y 2012/1/8 1:08
         Re: Flywheel bolts failure\fix\questions Dion120Y 2012/1/8 4:12
           Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/8 4:38
           Re: Flywheel bolts failure\fix\questions Dion120Y 2012/1/8 6:31
             Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/8 7:16
       Re: Flywheel bolts failure\fix\questions A14force 2012/1/8 1:19
       Re: Flywheel bolts failure\fix\questions estyre 2012/1/8 1:37
       Re: Flywheel bolts failure\fix\questions jmac 2012/1/8 2:20
         Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/8 2:45
       Re: Flywheel bolts failure\fix\questions Dundee1000 2012/1/8 2:56
       Re: Flywheel bolts failure\fix\questions Rusty-Wrench 2012/1/8 6:05
       Re: Flywheel bolts failure\fix\questions Rusty-Wrench 2012/1/8 7:16
         Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/8 7:24
       Re: Flywheel bolts failure\fix\questions Lemonhead 2012/1/8 8:14
       Re: Flywheel bolts failure\fix\questions jmac 2012/1/8 8:34
         Re: Flywheel bolts failure\fix\questions ang94541 2012/1/8 8:46
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/8 12:30
       Re: Flywheel bolts failure\fix\questions Dion120Y 2012/1/8 13:53
       Re: Flywheel bolts failure\fix\questions Lemonhead 2012/1/8 21:41
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/15 0:00
       Re: Flywheel bolts failure\fix\questions DJF280 2012/1/15 1:28
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/23 6:39
         Re: Flywheel bolts failure\fix\questions ddgonzal 2012/1/23 7:49
           Re: Flywheel bolts failure\fix\questions qik1000 2012/1/23 9:36
       Re: Flywheel bolts failure\fix\questions Rusty-Wrench 2012/1/24 4:20
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/1/24 12:27
         Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/2/13 5:01
           Re: Flywheel bolts failure\fix\questions Anonymous 2012/2/13 6:56
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/2/13 11:46
         Re: Flywheel bolts failure\fix\questions Lemonhead 2012/2/13 22:00
       Re: Flywheel bolts failure\fix\questions D 2012/2/14 3:14
         Re: Flywheel bolts failure\fix\questions LittleFireyOne 2012/2/14 10:41
       Re: Flywheel bolts failure\fix\questions LittleFireyOne 2016/1/9 3:44
         Re: Flywheel bolts failure\fix\questions ddgonzal 2016/1/9 3:58
           Re: Flywheel bolts failure\fix\questions LittleFireyOne 2016/1/9 5:41
             Re: Flywheel bolts failure\fix\questions ddgonzal 2016/1/9 5:53
