Re: A12 Rebuild
You don't need any special pressure on them as you do with hydraulic lifters.
Just turn the crank to TDC mark, and adjust 4 of the valves, then turn it one full turn to TDC again, and adjust the other 4 valves. You just need to determine which TDC you start with.
The procedure is in every repair manual or in our tech article Valve adjustment.
By the way, if you put in a new camshaft and/or lifters, be sure when you start it to immediately run it at 2000 RPM for 15 minutes. Don't let it idle.
Posted on: 2012/1/4 10:36
Subject Poster Date
     A12 Rebuild firstdatsun 2012/1/4 9:47
       Re: A12 Rebuild ddgonzal 2012/1/4 10:36
         Re: A12 Rebuild firstdatsun 2012/1/7 2:00
