Re: Source for stock A15 pistons with 10cc or less dish??
From Las Vegas USA
I can find stock pistons but they are all 12cc dish, which if I go up to 78mm would get the compression to 9.91-1 which would be close enough. I actually ordered a couple from various sources ($10 close outs) but to no avail.
I tried the part numbers for 210 and 310. Basically I'm trying to do this on my usual uber-cheap budget. If I just go as is compression will be 9.37-1,realistically going to 10-1 will probably only bring about 4-5hp but the goal is 100 RWHP (current A12 is about 80).
Of course I should stop dorking around and attempt build a proper motor that is in the 120 RWHP range. Using the cylinder head on the A12 would keep the cost down, maybe as low as $1200-1500......proper pistons being the bulk of it.
Tom
Posted on: 2012/1/25 2:19
Subject Poster Date
     Source for stock A15 pistons with 10cc or less dish?? Rallytwit 2012/1/24 2:47
       Re: Source for stock A15 pistons with 10cc or less dish?? bige 2012/1/24 3:14
       Re: Source for stock A15 pistons with 10cc or less dish?? Rusty-Wrench 2012/1/24 4:36
       Re: Source for stock A15 pistons with 10cc or less dish?? bige 2012/1/24 4:44
         Re: Source for stock A15 pistons with 10cc or less dish?? ddgonzal 2012/1/24 5:45
           Re: Source for stock A15 pistons with 10cc or less dish?? Rallytwit 2012/1/25 2:19
             Re: Source for stock A15 pistons with 10cc or less dish?? 58custom 2012/1/25 2:48
       Re: Source for stock A15 pistons with 10cc or less dish?? Rallytwit 2012/1/25 4:51
