Re: Cast piston brands- Opinions of two brands?
100 hp is nothing for the stock Nissan pistons. No need for customs. The stockers can do 8500 RPM.
Getting 10:1 will be difficult with the large chambers of the H89. The best thing to do is get flat-top pistons -- they will take advantage of the quench too. Milling the head a large amount will raise compression, but the dish pistons won't have a good quench.
Most guy use large overbore 79mm pistons. No only will flat-tops give more power but the extra 100cc gives a bigger power boost than the compression ratio change.
Posted on: 2012/2/9 3:18
Subject Poster Date
     Cast piston brands- Opinions of two brands? 58custom 2012/2/8 20:14
       Re: Cast piston brands- Opinions of two brands? ddgonzal 2012/2/9 3:18
         Re: Cast piston brands- Opinions of two brands? 58custom 2012/2/9 20:17
           Re: Cast piston brands- Opinions of two brands? ddgonzal 2012/2/10 0:00
