Re: Wheels - Centre Bore
From Sydney
I agree with Wards advice,the "shock loads" of suspension movements should ideally be transferred through correct wheel fitment on the hub. The wheel studs are there to hold the wheel on as there primary function, otherwise they will be subject to "shear" loads and may fail at some point. El-cheapo wheel spacers are a great example of exaggerating the problem, the hub centric type are the way to go.
Posted on: 2012/2/28 3:00
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Subject Poster Date
     Wheels - Centre Bore Wilfred 2012/2/27 5:30
       Re: Wheels - Centre Bore 1200rallycar 2012/2/27 5:50
         Re: Wheels - Centre Bore 1200rallycar 2012/2/27 5:59
       Re: Wheels - Centre Bore wards 2012/2/27 10:36
         Re: Wheels - Centre Bore 1200rallycar 2012/2/27 10:46
           Re: Wheels - Centre Bore supafatto 2012/2/27 11:12
             Re: Wheels - Centre Bore CA_1200_project 2012/2/27 11:24
               Re: Wheels - Centre Bore supafatto 2012/2/27 11:47
       Re: Wheels - Centre Bore wards 2012/2/27 12:44
         Re: Wheels - Centre Bore supafatto 2012/2/27 12:53
           Re: Wheels - Centre Bore 1200rallycar 2012/2/27 19:08
       Re: Wheels - Centre Bore Wilfred 2012/2/27 22:34
         Re: Wheels - Centre Bore supafatto 2012/2/28 21:54
           Re: Wheels - Centre Bore 1200rallycar 2012/2/28 23:40
             Re: Wheels - Centre Bore supafatto 2012/2/28 23:44
               Re: Wheels - Centre Bore 1200rallycar 2012/2/28 23:49
       Re: Wheels - Centre Bore wards 2012/2/28 2:15
         Re: Wheels - Centre Bore 1200rallycar 2012/2/28 2:29
       Re: Wheels - Centre Bore benny 2012/2/28 3:00
       Re: Wheels - Centre Bore Wilfred 2012/2/28 4:32
       Re: Wheels - Centre Bore L18_B110 2012/2/29 1:48
