Re: How to identify dogleg 5 speed?
From Fremantle, West Australia
If it has "60" cast into it
it could be
4speed
5 speed std patern
5 speed dogleg pattern
IF its a 5 speed dogleg, the drain plug will point to the REAR, not downward as is the case for the std pattern 5 speed
or simply put it in gear in the TOP LEFT position and then turn the input shaft. If the output shaft turns the OPPOSITE direction, its a dogleg 5 speed (FS5W60L) ie you are in reverse in the top left position
to easily see the output shaft rotation direction, push on a short piece of 19mm poly retic pipe or a plastic water bottle onto the output shaft
Posted on: 2012/3/13 14:49
69 KB10 (A15 + 5 speed one day)
68 VB10 granny spec
Subject Poster Date
     How to identify dogleg 5 speed? datgx 2012/2/29 3:41
       Re: How to identify dogleg 5 speed? Wilfred 2012/2/29 4:06
       Re: How to identify dogleg 5 speed? switzergt5 2012/3/11 2:34
         Re: How to identify dogleg 5 speed? evilsim 2012/3/11 2:50
       Re: How to identify dogleg 5 speed? Dion120Y 2012/3/13 10:10
         Re: How to identify dogleg 5 speed? datgx 2012/3/13 10:12
           Re: How to identify dogleg 5 speed? Anonymous 2012/3/13 14:11
       Re: How to identify dogleg 5 speed? Weekend1000 2012/3/13 14:49
         Re: How to identify dogleg 5 speed? datgx 2012/3/13 20:58
       Re: How to identify dogleg 5 speed? grant76 2012/3/13 21:55
       Re: How to identify dogleg 5 speed? orange-1200 2012/3/13 22:14
       Re: How to identify dogleg 5 speed? Weekend1000 2012/3/14 2:59
       Re: How to identify dogleg 5 speed? bakat 2012/3/14 7:55
       Re: How to identify dogleg 5 speed? Dion120Y 2012/3/14 8:41
