Re: Aftermarket panel fitment
Front guards, there's a small lip that is a little long on the inner guard section, will take pics, can email if need asap, pm me if so! If not I'll post up some stage tomorrow!
I had to cut a little off of the inner guard, open door and cheak, you'll see where hits first! Trim to suit!
Also fit rear eye bolt first and stretch a little as needed!
Then you need to put all other bolts in loose!
Once all in and good matching to doors and bonnet tighten bolts!
The only place I had to shape was near the cowl as it sat a little low when I lined mine up!
I also had to press a little on lower section near doors till sat right!
Hopes this helps
Posted on: 2012/3/31 8:33
Car free
Subject Poster Date
     Aftermarket panel fitment cracka50 2012/3/30 11:36
       Re: Aftermarket panel fitment hotrocket 2012/3/30 11:42
       Re: Aftermarket panel fitment coochee 2012/3/31 8:25
         Re: Aftermarket panel fitment supafatto 2012/3/31 8:33
           Re: Aftermarket panel fitment mcdat 2012/3/31 8:53
       Re: Aftermarket panel fitment hotrocket 2012/3/31 9:35
         Re: Aftermarket panel fitment supafatto 2012/3/31 9:44
       Re: Aftermarket panel fitment StinkyRooster 2012/4/2 5:53
         Re: Aftermarket panel fitment supafatto 2012/4/2 5:58
         Re: Aftermarket panel fitment bailz 2012/4/2 5:59
           Re: Aftermarket panel fitment mcdat 2012/4/2 7:28
       Re: Aftermarket panel fitment cracka50 2012/4/2 9:00
         Re: Aftermarket panel fitment mcdat 2012/4/2 9:28
           Re: Aftermarket panel fitment supafatto 2012/4/2 9:43
             Re: Aftermarket panel fitment mcdat 2012/4/2 9:51
       Re: Aftermarket panel fitment cracka50 2012/4/2 10:25
