Re: Lca- which to use for bit more track
From Melbourne, Australia
the problem with all this adjustable suspension stuff... a proper wheel alignment to set castor, toe and camber will cost around $300
but once its it's set once you shouldn't have to play too much, unless you have a rally car too that has a tendency to bounce off solid things
Posted on: 2012/4/2 13:01
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Subject Poster Date
     Lca- which to use for bit more track Anonymous 2012/4/2 4:33
       Re: Lca- which to use for bit more track supafatto 2012/4/2 4:58
         Re: Lca- which to use for bit more track Anonymous 2012/4/2 5:31
           Re: Lca- which to use for bit more track supafatto 2012/4/2 5:54
             Re: Lca- which to use for bit more track supafatto 2012/4/2 5:55
       Re: Lca- which to use for bit more track levey 2012/4/2 11:59
         Re: Lca- which to use for bit more track supafatto 2012/4/2 12:11
           Re: Lca- which to use for bit more track 1200rallycar 2012/4/2 12:18
       Re: Lca- which to use for bit more track levey 2012/4/2 12:24
         Re: Lca- which to use for bit more track Anonymous 2012/4/2 12:51
           Re: Lca- which to use for bit more track Anonymous 2012/4/2 12:52
             Re: Lca- which to use for bit more track 1200rallycar 2012/4/2 13:01
             Re: Lca- which to use for bit more track supafatto 2012/4/2 13:03
       Re: Lca- which to use for bit more track levey 2012/4/3 11:00
         Re: Lca- which to use for bit more track Anonymous 2012/4/3 11:05
       Re: Lca- which to use for bit more track boofhead 2012/4/3 13:49
