Re: Throw out bearing ????
The Cluster Shaft in inside the transmission. It spins any time engine is running and clutch is dis-engaged. Even in Nuetral, the cluster shaft is spinning.
Throwout bearing:
* Clutch engaged (pedal down), bearing is spinning
* Clutch dis-engaged (pedal up), bearing should not be spinning if the clutch cable/pedal is correctly adjusted
Posted on: 2012/4/8 4:07
Subject Poster Date
     Throw out bearing ???? Izzy01 2012/4/8 2:36
       Re: Throw out bearing ???? wards 2012/4/8 3:12
         Re: Throw out bearing ???? Izzy01 2012/4/8 3:28
           Re: Throw out bearing ???? ddgonzal 2012/4/8 4:07
       Re: Throw out bearing ???? Izzy01 2012/4/8 4:36
       Re: Throw out bearing ???? Izzy01 2012/4/8 4:51
