Re: Pinion Bearing
for a 1981-1982, the engine compartment ID plate will tell you the ratio of the differential:
H150 came in:
3.545
3.700
3.889
3.545 is best for fuel-economy. 3.889 is best for performance. Remember to adjust your speedometer if changing ratios or tire diameter.
jpg  H150_ID.jpg (27.36 KB)
174_4fb4076aeaeb9.jpg 400X300 px
Posted on: 2012/5/16 20:59
Subject Poster Date
     Pinion Bearing AgentWright007 2012/5/16 14:59
       Re: Pinion Bearing AgentWright007 2012/5/16 15:01
         Re: Pinion Bearing supafatto 2012/5/16 15:05
           Re: Pinion Bearing AgentWright007 2012/5/16 15:12
             Re: Pinion Bearing AgentWright007 2012/5/16 15:28
               Re: Pinion Bearing AgentWright007 2012/5/16 16:24
                 Re: Pinion Bearing ddgonzal 2012/5/16 18:25
                   Re: Pinion Bearing AgentWright007 2012/5/16 19:26
       Re: Pinion Bearing ddgonzal 2012/5/16 20:35
         Re: Pinion Bearing ddgonzal 2012/5/16 20:59
