Re: Speedo reading about 30km/h too fast
That's pretty close to being 'proportionate' (in other words, for every 10 km/h of road speed it will read 3km/h differently.
This is good because it means that it could be corrected (or at least brought close enough to be more than satisfactory) by either the speedo corrector box, or a different speedo gear (if available)
What I'd also suggest is to see what the error is like at 140km/h or so. NOW I WANT TO BE CLEAR here - I DON'T MEAN to go out and do that sort of speed on the road, but if you carefully jack the car up and put axle stands under the resr axle tubes, and chock the front wheels (also have nobody in front or behind the car at the time) you can carefully get it up to that sort of speed in top gear, with the wheels off the ground. Obviously be ready with your left foot, resting on the brake pedal (very lightly) and be ready that if the car rocks or looks about to fall (which is highly unlikely if you place the stands properly) - you just jump on the brake pedal (lift off the accelerator at the same time) and let the car stall, it'll limit the 'jump' to a very short distance even if it did tip off the stands.
Anyway - get a look at what it is doing at that 'simulated' road speed - you might finally see it start to get a bit 'jumpy' with the needle jerking back and forth.
If that doesn't happy, the speedo internals are mostly in good shape, adn the altered drive gear/corrector box/ or simply just a home made guage 'sticker' with the speeds where they need to be to match the needle position at that speed - well - it means any of these will be very successful.
If it 'was' jumping back and forth a lot, you'll find that it'll likely get worse over time and a new sticker/decal or swapped gear or corrector box would only fix it for a short time.
Posted on: 2012/7/9 8:05
John McKenzie
Subject Poster Date
     Speedo reading about 30km/h too fast BeeJJ 2012/7/3 13:27
       Re: Speedo reading about 30km/h too fast Anonymous 2012/7/3 15:14
         Re: Speedo reading about 30km/h too fast ddgonzal 2012/7/3 18:30
           Re: Speedo reading about 30km/h too fast estyre 2012/7/4 2:33
             Re: Speedo reading about 30km/h too fast ddgonzal 2012/7/4 3:24
       Re: Speedo reading about 30km/h too fast jmac 2012/7/4 9:41
         Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/4 10:14
           Re: Speedo reading about 30km/h too fast ddgonzal 2012/7/4 17:50
             Re: Speedo reading about 30km/h too fast Anonymous 2012/7/4 22:54
       Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/5 0:46
       Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/5 23:27
         Re: Speedo reading about 30km/h too fast ddgonzal 2012/7/5 23:49
           Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/6 0:05
       Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/7 8:40
       Re: Speedo reading about 30km/h too fast ddgonzal 2012/7/8 2:39
         Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/8 3:23
       Re: Speedo reading about 30km/h too fast jmac 2012/7/9 8:05
         Re: Speedo reading about 30km/h too fast BeeJJ 2012/7/9 8:27
       Re: Speedo reading about 30km/h too fast Anonymous 2012/7/9 10:15
