Re: Headlight Problem
Low beams should come on when the Headlight switch is pulled all the way out.
The dimmer switch (turn signal switch) controls high beam vs low beam. With switch pulled back towards driver, low beams should light. With switch pushed forward, low beams go out and high beams light.
Posted on: 2012/8/4 3:16
Subject Poster Date
     Headlight Problem UTE18L 2012/7/30 5:03
       Re: Headlight Problem Anonymous 2012/7/30 5:37
         Re: Headlight Problem UTE18L 2012/7/30 5:42
       Re: Headlight Problem Anonymous 2012/7/30 5:46
       Re: Headlight Problem nismo 2012/7/30 9:25
       Re: Headlight Problem orange-1200 2012/7/30 9:39
         Re: Headlight Problem ddgonzal 2012/7/30 19:20
           Re: Headlight Problem UTE18L 2012/7/31 0:31
             Re: Headlight Problem UTE18L 2012/8/1 3:57
               Re: Headlight Problem Anonymous 2012/8/1 4:39
       Re: Headlight Problem Shoota_77 2012/7/31 0:37
         Re: Headlight Problem Anonymous 2012/7/31 1:11
           Re: Headlight Problem UTE18L 2012/7/31 1:36
             Re: Headlight Problem Shoota_77 2012/7/31 1:56
       Re: Headlight Problem Rallytwit 2012/7/31 2:01
       Re: Headlight Problem UTE18L 2012/8/4 2:27
         Re: Headlight Problem ddgonzal 2012/8/4 3:16
           Re: Headlight Problem UTE18L 2012/8/4 4:32
             Re: Headlight Problem UTE18L 2012/8/4 4:34
               Re: Headlight Problem ddgonzal 2012/8/4 6:28
                 Re: Headlight Problem ddgonzal 2012/8/4 6:39
       Re: Headlight Problem UTE18L 2013/2/3 9:02
