Re: Fuel consumption on twin weber a14
Depends on the camshaft and tune but to beat a 80kg heavier golf mk1 with a 2L youll need a fair bit of poke and best go for A15 crank and bigger bores at least closer to 1600cc.
Depends where you are but a place I go to are able to use e15et conrods on offset ground A15 crank using custom cast pistons for 84mm stroke and 82.5mm bores on sleeved A14 /a15 block. 1796cc yet at the end of the day supercharged A15 is better.
Posted on: 2012/8/3 4:13
Subject Poster Date
     Fuel consumption on twin weber a14 PJtwinweber 2012/8/2 13:42
       Re: Fuel consumption on twin weber a14 Stock1200Ute1 2012/8/2 14:03
       Re: Fuel consumption on twin weber a14 D 2012/8/2 14:18
         Re: Fuel consumption on twin weber a14 greendog 2012/8/2 14:49
           Re: Fuel consumption on twin weber a14 ddgonzal 2012/8/2 22:09
         Re: Fuel consumption on twin weber a14 D 2012/8/3 4:13
           Re: Fuel consumption on twin weber a14 Stock1200Ute1 2012/8/3 4:46
             Re: Fuel consumption on twin weber a14 D 2012/8/3 5:19
               Re: Fuel consumption on twin weber a14 BEN510 2012/8/3 10:02
       Re: Fuel consumption on twin weber a14 PJtwinweber 2012/8/3 19:01
       Re: Fuel consumption on twin weber a14 lamb_daiquiri 2012/8/4 1:21
