JE Piston part no. for A series?
From NZ
Hi - does anyone have a part number I can try for JE Pistons? I have damaged No.1 piston (JE) in my race engine but unfortunately haven't yet been able to ascertain the part no. (I purchased the engine second hand some years ago).
Pistons are:
Flat top, with valve reliefs
Bore 78mm
18mm piston pin (full floating/circlipped. Brass bush pressed into conrod)
1mm top ring/1.2mm 2nd ring/3 piece oil control ring
Engine is A12A FWIW
Any and all suggestions gratefully received!
Thanks
Posted on: 2012/8/5 12:17
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Subject Poster Date
     JE Piston part no. for A series? Fandatstick 2012/8/5 12:17
       Re: JE Piston part no. for A series? sikyne 2012/8/5 12:37
       Re: JE Piston part no. for A series? Rallytwit 2012/8/6 2:50
