Re: 88 Celcius Thermostat
as long as you have a good supply of clean fresh air getting to your air filter, and your cooling system is in good condition, then the higher water temps will actually help with efficiency, make the engine warm up better and keep the oil closer to the perfect temp and pressure.
Only thing you have to watch, is underbonnet temps, but with such a minor increase in temps, I doubt it will be affected
Posted on: 2012/8/31 8:41
Subject Poster Date
     88 Celcius Thermostat Sumith 2012/8/30 8:15
       Re: 88 Celcius Thermostat 1200rallycar 2012/8/30 8:17
       Re: 88 Celcius Thermostat StinkyRooster 2012/8/31 8:41
         Re: 88 Celcius Thermostat Sumith 2012/9/5 11:10
