Re: Carbies
Quite a regular
From Brisbane
I am no expert but my engine suffered from flat spots when under load at higher revs.
I adjusted a number of different things to fix the problem however if the problem has started since the introduction of the elec distributor than i would start there. What coil are you using with the elec dizzy? Are you still running a ballast resistor?
Posted on: 2012/9/13 0:53
Subject Poster Date
     Carbies davem69 2012/9/12 13:12
       Re: Carbies Anonymous 2012/9/12 13:31
         Re: Carbies davem69 2012/9/12 13:56
       Re: Carbies johnb 2012/9/13 0:53
         Re: Carbies 1200rallycar 2012/9/13 4:13
           Re: Carbies davem69 2012/9/13 18:16
             Re: Carbies davem69 2012/9/17 9:52
       Re: Carbies lightload 2012/9/17 23:03
         Re: Carbies davem69 2012/9/18 0:58
           Re: Carbies 1200rallycar 2012/9/18 2:30
             Re: Carbies davem69 2012/9/20 7:45
               Re: Carbies davem69 2012/10/13 14:46
                 Re: Carbies townie 2012/10/13 23:53
                   Re: Carbies 1200rallycar 2012/10/14 1:05
                     Re: Carbies Anonymous 2012/10/14 1:09
                       Re: Carbies davem69 2012/10/14 4:27
                         Re: Carbies 1200rallycar 2012/10/14 5:43
                           Re: Carbies davem69 2012/10/15 2:45
