Re: a12 pilot bush
From Perth
Doesn't the Dellow bush actually go into the flywheel not the back of the crank as the input shaft is shorter on the Celica box than the Datto one... so your input shaft might flop around and drop a front bearing or worse ?
I'm only assuming this as I run a bearing in the centre of the flywheel rather than a bush anyway so I'm not 100% sure
Posted on: 2012/9/22 7:54
Subject Poster Date
     a12 pilot bush stumackloud 2012/9/22 0:38
       Re: a12 pilot bush benny 2012/9/22 4:21
         Re: a12 pilot bush dattoman_1000 2012/9/22 7:54
           Re: a12 pilot bush stumackloud 2012/9/23 2:49
