Re: Sway Bar.
From Brisbane, Australia
Benny, if you're going to that much trouble, may as well make them blade adjustable as well rather than those solid arms in the pic.
I used to adjust the rear swaybar by moving the U-shackle mounting points on the diff and loosening/tightening the nyloc nuts on the links, or swapping some poly bushes for rubber or vice-versa. It all works and its free. Making all that stuff fixed rose joints like in that pic is taking away the tuning you had with the more basic setup. To me that's a step backwards for a track car.
Posted on: 2012/10/23 22:59
Subject Poster Date
     Sway Bar. darrenwilson 2012/10/11 0:45
       Re: Sway Bar. ddgonzal 2012/10/11 1:14
         Re: Sway Bar. darrenwilson 2012/10/11 1:17
       Re: Sway Bar. orange-1200 2012/10/11 14:14
         Re: Sway Bar. shanepickett 2012/10/11 14:41
           Re: Sway Bar. darrenwilson 2012/10/11 22:18
             Re: Sway Bar. ddgonzal 2012/10/12 0:25
               Re: Sway Bar. L18_B110 2012/10/12 0:41
                 Re: Sway Bar. ddgonzal 2012/10/12 3:18
                   Re: Sway Bar. L18_B110 2012/10/18 4:57
             Re: Sway Bar. ddgonzal 2012/10/14 5:30
       Re: Sway Bar. jmac 2012/10/13 7:16
         Re: Sway Bar. Anonymous 2012/10/13 8:18
         Re: Sway Bar. L18_B110 2012/10/18 5:24
           Re: Sway Bar. B110SSS 2012/10/18 6:53
       Re: Sway Bar. jmac 2012/10/18 8:43
       Re: Sway Bar. sikyne 2012/10/18 9:40
       Re: Sway Bar. L18_B110 2012/10/19 5:26
         Re: Sway Bar. B110SSS 2012/10/19 9:57
           Re: Sway Bar. Rallytwit 2012/10/20 5:27
             Re: Sway Bar. darrenwilson 2012/10/20 10:31
               Re: Sway Bar. Anonymous 2012/10/20 10:55
             Re: Sway Bar. L18_B110 2012/10/22 0:22
       Re: Sway Bar. Stock1200Ute1 2012/10/22 4:18
       Re: Sway Bar. darrenwilson 2012/10/22 5:05
         Re: Sway Bar. ddgonzal 2012/10/22 5:46
       Re: Sway Bar. Rallytwit 2012/10/23 5:15
         Re: Sway Bar. benny 2012/10/23 8:19
       Re: Sway Bar. Wilfred 2012/10/23 11:23
       Re: Sway Bar. L18_B110 2012/10/23 22:59
