Re: A15 idle
Not too shy to talk
From SOUTH AFRICA
It might help if you take the carb and clean it with air and specifically check your idling jet for blockage. check the electrical wiring as well on the valve/solenoid. Worst case scenario strip,clean everything very well,dry, check jets and reasemble.
Or you can just chuck it and fit a weber !!!
Good luck
P
Posted on: 2012/10/26 19:29
Subject Poster Date
     A15 idle DAT5MAD 2012/10/26 10:09
       Re: A15 idle PITBULL 2012/10/26 19:29
         Re: A15 idle ddgonzal 2012/10/26 21:09
