Re: Brake master pump problem
Brake Master Cylinder (i've not heard it called a pump)
If it is a new Master, or a rebuilt Master you are installing, you must bleed the Master before you bleed the wheel cylinders. Otherwise it may not pressurize the lines.
Posted on: 2012/10/29 7:21
Subject Poster Date
     Brake master pump problem Sumith 2012/10/29 6:58
       Re: Brake master pump problem ddgonzal 2012/10/29 7:21
         Re: Brake master pump problem Sumith 2012/10/29 7:50
           Re: Brake master pump problem Sumith 2012/10/29 7:59
       Re: Brake master pump problem ddgonzal 2012/10/29 18:02
         Re: Brake master pump problem Sumith 2012/10/30 3:59
       Master Cylinder kills me Sumith 2012/11/5 4:39
