Re: 700 or 750kg?
From Stone Age somewhere in U.S.A.
ACTUALLY IT IS CORRECT
standard Nissan practice was/is to give weights with all fluids in place including a full fuel tank. the discrepency between the coupe listed at 1609 lb. and 1640 lb. is the difference in model years, the 1609 lb. figure is for a 1971 model, while the 1640 lb.figure is for a 1973 model.
for the 1973 model year, the bumpers on USA models were heavier as they were required to pass a 5 mph crash test.
the 2 dr. sedan is definatly the lightest weight of the 4 bodys produced, but that difference is so small that it won't make that big of a difference, the coupe having a lower over all height more than makes up for it with a lower center of gravity
Posted on: 2002/4/27 6:46
Subject Poster Date
     700 or 750kg? 1200rallycar 2002/4/27 0:38
       Re: 700 or 750kg? ddgonzal 2002/4/27 1:06
         Re: 700 or 750kg? rgrinder 2002/4/27 6:46
           Re: 700 or 750kg? Jesse 2002/4/27 16:05
             Re: 700 or 750kg? teretonga 2002/5/2 12:13
               Re: 700 or 750kg? Jesse 2002/5/2 15:58
