Re: Advise on single 45 DCOE for stock A15
40mm is better for your setup as mentioned or smaller.
or ... ask PJZ for one of his race heads as you will otherwise need to upgrade to an oval port head or use bigger valves and ported normal round port head, springs, shaved for higher comp, good ignition, headers and a mild camshaft. to run the 45mm.
Peter has heads all ready done and way cheaper posted.
Posted on: 2013/1/1 5:49
Subject Poster Date
     Advise on single 45 DCOE for stock A15 huicho 2012/12/31 23:57
       Re: Advise on single 45 DCOE for stock A15 pjz 2013/1/1 0:10
         Re: Advise on single 45 DCOE for stock A15 COUP1200 2013/1/1 0:19
         Re: Advise on single 45 DCOE for stock A15 Stock1200Ute1 2013/1/1 0:23
           Re: Advise on single 45 DCOE for stock A15 ddgonzal 2013/1/1 1:06
       Re: Advise on single 45 DCOE for stock A15 huicho 2013/1/1 3:02
         Re: Advise on single 45 DCOE for stock A15 ddgonzal 2013/1/1 3:39
           Re: Advise on single 45 DCOE for stock A15 D 2013/1/1 5:49
