Re: Compression testing question
From Snohomish, WA USA
I usually count 10 times. I put the gauge in a position where I can see it between the dash and the hood and watch it go up. 10 cranks and it usually is done. Good compression on a stock A series A15 is around 140-160psi. If all cylinders are with-in 10psi then your good. Others may have something different. That's just what I have found.
Posted on: 2013/1/17 4:48
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     Compression testing question SunnyDaze 2013/1/17 4:15
       Re: Compression testing question ddgonzal 2013/1/17 4:44
       Re: Compression testing question datsa73 2013/1/17 4:48
         Re: Compression testing question ddiesel 2013/1/17 9:51
