Re: brake master help
280ZX uses 15/16" master cylinder.
B310 uses 13/16" master cylinder. Remove the Residual Valve for use with rear discs.
When swapping master cylinders, you likely will need to mod the firewall for a new bolt-pattern and adjust the pushrod to the correct length.
Posted on: 2013/1/27 1:50
Subject Poster Date
     brake master help srdatsun 2013/1/25 12:02
       Re: brake master help Anonymous 2013/1/25 14:48
         Re: brake master help srdatsun 2013/1/26 10:40
       Re: brake master help b310gx 2013/1/26 21:45
         Re: brake master help ddgonzal 2013/1/27 1:50
           Re: brake master help shanepickett 2013/1/27 8:02
       Re: brake master help ddgonzal 2013/1/27 19:25
         Re: brake master help srdatsun 2013/1/28 10:19
       Re: brake master help shanepickett 2013/1/28 12:36
         Re: brake master help mad120y 2013/1/28 21:54
       Re: brake master help srdatsun 2013/2/4 5:27
