Clutch noise. Bad throwout bearing?
Ok ever since fitting a new clutch and a reco gearbox a while ago I had the following symptom:
When the clutch pedal is fully out there is noise. Lightly press on clutch pedal and the noise disappears.
This is a bad throwout bearing, right?
Funny thing is it has done this I replaced the clutch, so if it is the throwout it was bad since new.
Posted on: 2013/2/4 10:38
Subject Poster Date
     Clutch noise. Bad throwout bearing? SunnyDaze 2013/2/4 10:38
       Re: Clutch noise. Bad thowout bearing? SXC-DTO 2013/2/4 10:45
       Re: Clutch noise. Bad throwout bearing? SunnyDaze 2013/2/4 10:50
         Re: Clutch noise. Bad throwout bearing? Anonymous 2013/2/4 11:13
           Re: Clutch noise. Bad throwout bearing? SXC-DTO 2013/2/4 11:21
             Re: Clutch noise. Bad throwout bearing? ddgonzal 2013/2/4 18:16
       Re: Clutch noise. Bad throwout bearing? SunnyDaze 2013/2/5 0:11
         Re: Clutch noise. Bad throwout bearing? ddgonzal 2013/2/5 1:52
         Re: Clutch noise. Bad throwout bearing? Anonymous 2013/2/5 1:54
       Re: Clutch noise. Bad throwout bearing? SunnyDaze 2013/2/5 2:35
