Re: Steering Box Repair?
Up to 1" play is normal and does not indicate a worn box. Check to see if it is worn out. Wiggle the steering wheel back and forth with your pinky. Look under the car at the same time to ensure the steering box gear arm is not moving -- if it is you are applying too much force to the wheel for this test.
If the steering wheel moves up/down, that is the column bushing, easily replaceable new from Nissan.
If the steering wheel moves in/out it indicates the steering wheel needs to be tightened down.
Posted on: 2013/2/6 21:22
Subject Poster Date
     Steering Box Repair? CrazyHawaiian 2013/2/6 20:44
       Re: Steering Box Repair? ddgonzal 2013/2/6 20:47
         Re: Steering Box Repair? ddgonzal 2013/2/6 21:22
