Browsing this Thread:
1 Anonymous Users
Re: Timing mark moves |
From Gold Coast Queensland, Australia
Okay. I replaced the timing tensioner. It started and drove the other day. Went to fill up with fuel and it didn't make it home. I noticed the coil was quite hot. Is it likely that bad earth or wires could cause this and in turn making the weak spark? I am setting the initial timing to 7 degrees btdc but on the light it reads around 18-20. Is this normal? The revs are up around 1000 rpm at idle. I thought vac advance only kicks in after that. Also the mechanic said I could set initial at 12 degrees. I think it's gremlins. Might have to take it to auto electrician I guess
Posted on: 2013/3/20 5:30
