Re: 1200 ute CA18det initial start-up
From Mudgee NSW Australia
Hey chris hows your project going? Cant wait to catch up with you all again at the nationals although its a long time off. Im starting to get exited about it. Especailly the track time at oran park. Im pulling my donk out next weekend to give her a set of rings and fix some oil and coolant leaks the coolant leak worries me as it looks like the steel hose that is pressed into the block is weeping around the base :(
With your engine build did you use new or aftermarket rod bolts?? Im trying to source a set of ARP bolts if you know of where i can get some let me know.
Cheers Andrew
Posted on: 2002/7/7 8:46
Subject Poster Date
     1200 ute CA18det initial start-up NO1200 2002/7/3 8:32
       Re: 1200 ute CA18det initial start-up dimlight65 2002/7/3 14:19
         Re: 1200 ute CA18det initial start-up NO1200 2002/7/4 3:53
           Re: 1200 ute CA18det initial start-up dattodude 2002/7/5 0:39
             Re: 1200 ute CA18det initial start-up ca18det_man 2002/7/7 8:46
