Re: Nissan Heritage Collection - Sunny TS Cup specs
This is the TS-SUNNY Race Spec Engine.
BASE ENGINE
NISSAN A12 Type
TYPE
2 Valve, Inline 4 Cylinder, Water cooled, OHV
DISPLACEMENT
1303cc
BORE x STROKE
77.0×70.0mm
COMPRESSION
12.5:1
PEAK POWER OUTPUT
170PS (8000rpm)
CYLINDER BLOCK
A12 (From Nissan Cherry)
CYLINDER HEAD
GX Type
HEAD GASKET
TOMEI POWERED 0.8mm
CAMSHAFT
TOMEI POWERED  78°7.75
VALVE
Intake 40.0mm, Exhaust 33.0mm
VALVE SPRING
TOMEI POWERED Double Spring
VALVE LIFTER
NISMO Hollow
PUSH ROD
TOMEI POWERED
ROCKER SHAFT
TOMEI POWERED
ROCKER ARM
Modified from Standard Bush
PISTON
FORGED MMR
CONROD
Standard with WPC Treatment
CRANKSHAFT
Standard with Modified Oil Galleries
CRANK PIN BEARING
NISMO
CRANK BEARING
NISMO
OIL PUMP
Race Spec
OIL PAN
TOMEI JIDOUSHA
VALVE PLATE
TOMEI JIDOUSHA
WATER PUMP
INTAKE MANIFOLD
TOMEI POWERED
EXHAUST MANIFOLD
TOMEI POWERED
CARBURETOR
WEBER 45DCOE9
AIR FUNNEL
TOMEI POWERED
IGNITION SYSTEM
NAGAI DENSHI CDI Crank Pickup Without Alternator.
SPARK PLUG
NGK 4304A-10
PLUG CORD
NAGAI DENSHI
OIL
WAKOS Synthetic
FLYWHEEL
TOMEI JIDOUSHA
CLUTCH COVER
NISMO
CLUTCH DISC
NISMO
FUEL PUMP
NISMO
TRANSMISSION
Race Spec F56A
DIFF
NISMO H150 LSD
FRONT SPRING
CUSCO
REAR SPRING
RACE SPEC
FRONT SHOCK
TRD
REAR SHOCK
TOMEI JIDOUSHA
BUSH
JODOUSHA KOUBU HIROTA
FRONT WHEEL
TOSCO 8J-13
REAR WHEEL
TOSCO 9J-13
FRONT TYRE
ADVAN Springs 205-500-13
REAR TYRE
ADVAN Springs 225-500-13
BREAK CALIPERS
NISMO MK63 Bench Rated
BREAK PADS
LUVIX
BREAK SHOES
LUVIX
FRONT SPOILER
TOMEI JIDOUSHA
REAR SPOILER
TOMEI JIDOUSHA
ROLL CAGE
GARAGE ALTEA
Posted on: 2013/4/30 11:16
Subject Poster Date
     Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/4/30 0:34
       Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/4/30 0:38
       Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/4/30 1:09
         Re: Nissan Heritage Collection - Sunny TS Cup specs a12grunt 2013/4/30 11:07
           Re: Nissan Heritage Collection - Sunny TS Cup specs a12grunt 2013/4/30 11:16
             Re: Nissan Heritage Collection - Sunny TS Cup specs LZSunny 2013/4/30 12:19
       Re: Nissan Heritage Collection - Sunny TS Cup specs dattimon 2013/6/2 15:17
       Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/28 1:10
         Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/28 2:52
           Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/28 3:48
             Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/28 4:16
               Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/28 5:31
       Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/28 15:05
         Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 0:07
           Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/29 0:51
             Re: Nissan Heritage Collection - Sunny TS Cup specs clyons8 2013/10/29 1:02
             Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 1:13
               Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 1:28
             Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 1:41
       Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/29 3:35
         Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 7:29
           Re: Nissan Heritage Collection - Sunny TS Cup specs a12grunt 2013/10/29 8:30
             Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/29 23:21
               Re: Nissan Heritage Collection - Sunny TS Cup specs a12grunt 2013/10/30 6:59
                 Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/30 10:58
       Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/30 11:37
         Re: Nissan Heritage Collection - Sunny TS Cup specs D 2013/10/30 14:29
           Re: Nissan Heritage Collection - Sunny TS Cup specs a12grunt 2013/10/31 5:04
           Re: Nissan Heritage Collection - Sunny TS Cup specs L18_B110 2013/10/31 5:29
