Re: H190 in coupe, what did you do for pinion snubber
From Las Vegas USA
Benny we must be running on the same track, there's a giant hole just off the circuit, that nasty critter bottomed a rear damper so hard it came loose.
I will be leaving the snubber off, the Addco bar is v shaped (pointy side up) inside the tunnel mounted just ahead of the snubber. When I mounted the sway bar 20+ years ago the fact that it was slightly off center didn't matter, the A15 has enough torque that the drive shaft just nicked it as the chassis heeled over. I got everything straight yesterday afternoon..............I missed my track day, I did break my standing rule of not entering the event till the car is ready to go and paid for it.
On the plus side the motor feels pretty good even with 1/2 throttle and low revs, I'll be out on an abandoned stretch of road (defunct mine) to run i the engine. We'll see how it goes just before I load it back up.
Tom
Posted on: 2013/5/7 5:05
Subject Poster Date
     H190 in coupe, what did you do for pinion snubber Rallytwit 2013/5/5 5:15
       Re: H190 in coupe, what did you do for pinion snubber ddgonzal 2013/5/6 4:19
         Re: H190 in coupe, what did you do for pinion snubber benny 2013/5/6 4:50
       Re: H190 in coupe, what did you do for pinion snubber Rallytwit 2013/5/7 5:05
