Browsing this Thread:
1 Anonymous Users
Re: electronic distributor coil |
Registered Users Contentmaster Usermaster
GT40 is a low-energy coil suitable for use with points distributor or electronic distributor. Since the GT40 has a built-in resistance, you must bypass the external ballast resistor when used with the stock points distributor. The GT40R is slightly different and uses the original ballast resistor.
Of course a high-energy coil is best for use with electronic ignition. The Bosch HEC715 or Nissan Pulsar coil work well.
Posted on: 2013/6/13 21:39
