Re: Diff & Gearbox Oil ??
From Good Old Knockfull, Tennessee, USA
Before trying to put the thick lube oil into a trans or diff, put it in hot water for 15 minutes. That will thin the lube oil and make for much easier flowing. I just bought a hose that threads onto the lube oil container and has a push/pull plug on the end. I take the shifter boot off and put the fill hose down through the the boot opening. I can see the fill plug through the opening so as not to overfill. I still have to go under the car to remove the fill plug from the trans but filling is much easier than laying on the ground.
Mareo
Posted on: 2002/8/8 12:27
Subject Poster Date
     Diff & Gearbox Oil ?? amshaw 2002/8/3 14:27
       Re: Diff & Gearbox Oil ?? mareospeedwagon 2002/8/3 14:48
         Re: Diff & Gearbox Oil ?? rgrinder 2002/8/3 22:04
           Re: Diff & Gearbox Oil ?? mareospeedwagon 2002/8/4 15:56
             Re: Diff & Gearbox Oil ?? rgrinder 2002/8/4 18:52
               Re: Diff & Gearbox Oil ?? amshaw 2002/8/8 10:36
                 Re: Diff & Gearbox Oil ?? ang94541 2002/8/8 11:45
                   Re: Diff & Gearbox Oil ?? amshaw 2002/8/8 12:14
                     Re: Diff & Gearbox Oil ?? mareospeedwagon 2002/8/8 12:27
               Re: Diff & Gearbox Oil ?? mareospeedwagon 2002/8/8 12:34
                 Re: Diff & Gearbox Oil ?? rgrinder 2002/8/9 5:51
       Re: Diff & Gearbox Oil ?? ddgonzal 2002/8/3 20:27
