Re: how much cam is too much?
From Las Vegas USA
A couple of things here:
The numbers from the cam card suggest it's likely 275-280 advertised duration and probably .420 lift.....is the Cam card Nissan or something else. If my guess is correct I'd expect that the lowest idle you will achieve is 1200-1500 RPM's. Do you remember what valve springs you fitted?? I suspect that with that Cam the motor will rev upwards of 7500 RPM's but obviously it would need the proper springs.
Finally that is a very cool car, can you tell us more about it.
Tom
Posted on: 2013/10/8 4:14
Subject Poster Date
     how much cam is too much? dennisg 2013/10/7 4:09
       Re: how much cam is too much? ddgonzal 2013/10/7 6:08
         Re: how much cam is too much? dennisg 2013/10/7 17:16
           Re: how much cam is too much? ddgonzal 2013/10/7 17:43
             Re: how much cam is too much? dennisg 2013/10/7 21:41
       Re: how much cam is too much? Rallytwit 2013/10/8 4:14
       Re: how much cam is too much? dennisg 2013/10/8 17:50
         Re: how much cam is too much? dennisg 2013/10/8 18:14
           Re: how much cam is too much? ddgonzal 2013/10/8 21:09
       Re: how much cam is too much? Rallytwit 2013/10/10 22:50
