GX ratios / engine specs
From Perth, West Aussie
as I am about to take delivery of a GX 5 speed, I would like to know the ratios of it if possible. will be a great improvement on the 130ks topend it has now .. but by no means its potential, the engine is just screaming its box off (this is a B10 with an A15 with weber and extractors.) as it is geared for the original 1000cc motor. the 12" rims arent helping either. I would also like to know what size inlet and exhaust valves the A15 has.
Cheers
Tom.
Posted on: 2002/8/19 12:12
Subject Poster Date
     GX ratios / engine specs shoom 2002/8/19 12:12
       Re: GX ratios / engine specs b310gx 2002/8/20 12:05
         Re: GX ratios / engine specs shoom 2002/8/20 12:55
           Re: GX ratios / engine specs ang94541 2002/8/20 17:42
             Re: GX ratios / engine specs b310gx 2002/8/20 21:26
               Re: GX ratios / engine specs mr_nismo4 2002/8/22 0:59
                 Re: GX ratios / engine specs olboy 2002/8/22 1:35
                   Re: GX ratios / engine specs mr_nismo4 2002/8/22 5:34
                     Re: GX ratios / engine specs b310gx 2002/8/22 10:27
                       Re: GX ratios / engine specs shoom 2002/8/22 12:11
                         Re: GX ratios / engine specs shoom 2002/8/22 17:53
                           Re: GX ratios / engine specs b310gx 2002/8/22 21:38
                       Re: GX ratios / engine specs stirlingmac 2002/8/22 21:35
                         Re: GX ratios / engine specs dattodude 2002/8/23 1:13
                           Re: GX ratios / engine specs b310gx 2002/8/26 22:41
             Re: GX ratios / engine specs shoom 2002/8/20 21:26
               Re: GX ratios / engine specs b310gx 2002/8/20 21:41
               Re: GX ratios / engine specs shoom 2002/8/20 21:42
                 Re: GX ratios / engine specs shoom 2002/8/20 21:49
             Re: GX ratios / engine specs shoom 2002/8/28 6:41
       Re: GX ratios / engine specs shoom 2002/8/21 10:49
         Re: GX ratios / engine specs b310gx 2002/8/21 11:44
           Re: GX ratios / engine specs b310gx 2002/8/21 12:04
             Re: GX ratios / engine specs shoom 2002/8/21 15:02
