Re: A15 rods: Do you resize when you replace rod bolts?
From Las Vegas USA
Remember that you can also order thinner head gaskets for the A-series engine, B-projects in Japan has them at .8mm thick. I can't remember if Nissan Motorsports still has them or if they are NLA. If you can actually find them there are pistons with a smaller dish, I think around 5-7cc, I tried to find a set but wasn't successful so I went to the JE ones.
Tom
Posted on: 2013/10/16 2:26
Subject Poster Date
     A15 rods: Do you resize when you replace rod bolts? 58custom 2013/10/14 3:39
       Re: A15 rods: Do you resize when you replace rod bolts? Rallytwit 2013/10/14 3:57
       Re: A15 rods: Do you resize when you replace rod bolts? 58custom 2013/10/14 4:18
       Re: A15 rods: Do you resize when you replace rod bolts? Rallytwit 2013/10/15 4:33
       Re: A15 rods: Do you resize when you replace rod bolts? 58custom 2013/10/15 5:26
       Re: A15 rods: Do you resize when you replace rod bolts? Rallytwit 2013/10/16 2:26
       Re: A15 rods: Do you resize when you replace rod bolts? 58custom 2013/10/16 18:01
       Re: A15 rods: Do you resize when you replace rod bolts? A14force 2013/10/18 10:32
