Re: Points to CDI conversion kits
From Adelaide
There's a fair bit of info on the web about it. CDI is better where you need higher voltages to get a spark. It's used in small engines and 2 strokes where fouling can be an issue and also in some high CR or high boost engines where getting a spark can be an issue.
The down side is the spark duration is shorter so it's not as good for lean burn or cruise conditions.
Edit: CDI is better for starting with low battery voltage compared to a standard Kettering system although many electronic ignitions have compensation.
Posted on: 2013/12/19 1:17
Edited by lamb_daiquiri on 2013/12/19 6:36:28
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Subject Poster Date
     Points to CDI conversion kits supercharger 2013/12/11 3:01
       Re: Points to CDI conversion kits ddgonzal 2013/12/11 7:31
         Re: Points to CDI conversion kits supercharger 2013/12/11 8:47
       Re: Points to CDI conversion kits zigmondo 2013/12/18 11:43
         Re: Points to CDI conversion kits Anonymous 2013/12/18 12:09
       Re: Points to CDI conversion kits lamb_daiquiri 2013/12/19 1:17
       Re: Points to CDI conversion kits supercharger 2013/12/23 4:39
