Re: stronger clutch for a 1200
First ensure the clutch is adjusted properly. If the is no play, it will slip.
A high RPM engine will usually have less
torque, so not hard on the clutch unless you are applying s lot of throttle while letting up on the clutch pedal.
Posted on: 2014/1/20 8:36
Subject Poster Date
     stronger clutch for a 1200 dennisg 2014/1/20 7:18
       Re: stronger clutch for a 1200 A14force 2014/1/20 8:11
       Re: stronger clutch for a 1200 ddgonzal 2014/1/20 8:36
       Re: stronger clutch for a 1200 ddgonzal 2014/1/20 8:40
         Re: stronger clutch for a 1200 Stock1200Ute1 2014/1/20 8:54
