Re: Wanted bluebird,r31,r32 speedo sender
Sender? You mean speedometer gear. Any 71C gear will work to replace am S13/S14 sender.
Remove the sender and fit a cable drive in its
place. Speedometer pinion & sleeve. Nissan part numbet 32703-N9019 is for Navara 19T.
You can also use a 71B pinion assembly by modifying the bolt tab. Basically most 5-speeds 1978-1985.
Posted on: 2014/3/16 16:17
Subject Poster Date
     Wanted bluebird,r31,r32 speedo sender hilton89 2014/3/16 10:28
       Re: Wanted bluebird,r31,r32 speedo sender ddgonzal 2014/3/16 16:17
       Re: Wanted bluebird,r31,r32 speedo sender hilton89 2014/3/18 9:03
