Re: Overheat or not to Overheat??
From Wanganui, New Zealand
Scott, it will be a mismatch between the new guage and the old sender unit. See what the make of new guage is and try to find a new sender unit that matches that. My bet is that the thermostat will be fine, and that you actually have no problem with the cooling system. It is just that the guage is giving you a false reading. Wiring the sender up (complete with an earth wire) and putting it into a pot of boiling water as mentioned by Angelo will certainly prove it.
Posted on: 2002/9/26 9:49
Subject Poster Date
     Overheat or not to Overheat?? Davo1200 2002/9/21 9:48
       Re: Overheat or not to Overheat?? datto_dave 2002/9/21 10:51
       Re: Overheat or not to Overheat?? rgrinder 2002/9/22 4:50
         Re: Overheat or not to Overheat?? Davo1200 2002/9/25 14:55
           Re: Overheat or not to Overheat?? Niscoupe 2002/9/26 9:49
       Re: Overheat or not to Overheat?? Niscoupe 2002/9/22 6:54
         Re: Overheat or not to Overheat?? ang94541 2002/9/22 7:28
