Re: Stopping the RREEERRGGHH!!! noise on starter motor
From Castro Valley,CA USA
one guy talked about machining the surface - but he is talking about moving the starter closer to the motor not further backward on the car, if you know what i mean, and i guess this is possible to move it a little bit closer to the motor because there is some clearance there from memory but i reckon all you need to do is get a starter in better nic
No, i meant machining the surface that mounts to the trans. That way the starter would move deeper into the trans. I was just commenting on how you might be able to adjust the starter since there are no shims.
I would rather replace the starter, too. It's much easier , cheaper , and probably the problem.
Posted on: 2002/9/23 5:22
Subject Poster Date
     Stopping the RREEERRGGHH!!! noise on starter motor Lobster 2002/9/21 14:27
       Re: Stopping the RREEERRGGHH!!! noise on starter motor ddgonzal 2002/9/21 20:46
       Re: Stopping the RREEERRGGHH!!! noise on starter motor ang94541 2002/9/22 7:08
       Re: Stopping the RREEERRGGHH!!! noise on starter motor teretonga 2002/9/22 12:49
         Re: Stopping the RREEERRGGHH!!! noise on starter motor 1200rallycar 2002/9/23 1:10
           Re: Stopping the RREEERRGGHH!!! noise on starter motor ang94541 2002/9/23 5:22
       Re: Stopping the RREEERRGGHH!!! noise on starter motor bent_axel_bob 2002/9/25 10:44
         Re: Stopping the RREEERRGGHH!!! noise on starter motor bent_axel_bob 2002/9/25 10:53
           Re: Stopping the RREEERRGGHH!!! noise on starter motor 1200rallycar 2002/9/25 11:37
             Re: Stopping the RREEERRGGHH!!! noise on starter motor Lobster 2002/9/27 12:58
               Re: Stopping the RREEERRGGHH!!! noise on starter motor flyby 2002/9/27 21:34
                 Re: Stopping the RREEERRGGHH!!! noise on starter motor ddgonzal 2002/9/28 3:27
