Re: a12 overfueling
Quite a regular
From neerim east victoria
if you have adjusted the float level and its still flooding you may have a bit of crap under the needle or its not seating,take the top off the carby,hold it upside down and make sure the float is holding the needle down,you can test buy sucking through the fuel inlet you should be able to hold a vaccuum [if that makes any sense] if you have an air comp a gentle blast may clean it out
Russ
Posted on: 2014/4/27 0:18
Subject Poster Date
     a12 overfueling shaun 2014/4/27 0:00
       Re: a12 overfueling zabond 2014/4/27 0:18
         Re: a12 overfueling ddgonzal 2014/4/27 1:39
           Re: a12 overfueling shaun 2014/4/27 6:42
             Re: a12 overfueling clyons8 2014/4/27 7:44
