Re: B210 FS5W63A into B310
1. Get the matching drive shaft from B210
2. Get the special clutch disc from B210
3. Gearbox cross member needs modification. The B310 automatic crossmember is likely the closest and has the right rubber insulator.
4. If your B310 has cable-operated clutch, convert it to hydraulic operated (master, pedal, and line).
Posted on: 2014/4/28 0:19
Subject Poster Date
     B210 FS5W63A into B310 tbone123 2014/4/27 23:39
       Re: B210 FS5W63A into B310 ddgonzal 2014/4/28 0:19
         Re: B210 FS5W63A into B310 tbone123 2014/4/28 0:30
           Re: Clutch disc for FS5W63A ddgonzal 2014/4/28 1:35
           Re: How do I tell if clutch is cable or hydraulic? ddgonzal 2014/4/28 2:57
             Re: B210 FS5W63A into B310 tbone123 2014/4/28 13:07
               Re: B210 FS5W63A into B310 ddgonzal 2014/4/28 17:43
