Re: running problems
Check the simple things first and work your way through the problem.
Start with the points/condensor on the distrubitor. Then check little things like fuses, change spark plugs, plug leads, etc.... Make sure the fuel filter is not clogged.
Check for vacuum leaks.
Posted on: 2014/4/30 11:00
Subject Poster Date
     running problems patydaty 2014/4/30 9:38
       Re: running problems datsunbeginner 2014/4/30 11:00
         Re: running problems patydaty 2014/4/30 12:49
           how do i fully check for vac leaks? ddgonzal 2014/4/30 21:33
             Re: running problems patydaty 2014/5/1 10:12
         Re: running problems Anonymous 2014/4/30 13:30
           Re: running problems ddgonzal 2014/4/30 21:25
       Re: running problems ddgonzal 2014/5/1 10:45
         Re: running problems patydaty 2014/5/1 11:28
           Re: running problems ddgonzal 2014/5/1 16:57
       Re: running problems rgrinder 2014/5/2 15:41
