Re: Bosch 044 vs Aeroflow fuel pump for CA18DET
From Ballarat Victoria
Do you mean Aeromotive(A1000, red with fins)?
I have only tuned one car with the Aeromotive pump. They are great for big engines that need a lot of fuel, but don't like high boost(high fuel pressure).
I had trouble with one at much above 15Psi and 400Kw. probably better for big engines with low boost.
The genuine 044 is good for high fuel pressures(high boost). I run mine to 6 Bar fuel pressure on boost.
Edit: I just googled AF49-1014. I didn't even know aeroflow made a pump. If its like most of their range, it will be a Chinese copy of another manufacturer. In this case Bosch. I wouldn't touch them personally.
I have only ever used one Aeroflow product, and it failed!
Posted on: 2014/6/1 1:22
VIC DYNO HIRE
Subject Poster Date
     Bosch 044 vs Aeroflow fuel pump for CA18DET DON_1200 2014/6/1 0:24
       Re: Bosch 044 vs Aeroflow fuel pump for CA18DET oda70 2014/6/1 0:57
       Re: Bosch 044 vs Aeroflow fuel pump for CA18DET sikyne 2014/6/1 1:22
         Re: Bosch 044 vs Aeroflow fuel pump for CA18DET clyons8 2014/6/1 5:06
       Re: Bosch 044 vs Aeroflow fuel pump for CA18DET Datrotor 2014/6/1 9:20
