Re: which ecu for use with ITBS ?
From Adelaide
I'm using mega squirt II with ITBs and an EDIS ignition. Well, I'll be using the EDIS when I get my pulley machined to fit the trigger wheel. I had an EDIS8 running off a trigger wheel in the dizzy but that wasn't reliable. Something funkey happened at around 5krpm. Seriously easy to tune the engine map with Tuner Studio (full version) and a wide band. Plug in, drive, autotune. Not expensive either. I haven't made much use of the logger license I paid for.
Posted on: 2014/6/23 9:56
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Subject Poster Date
     which ecu for use with ITBS ? estyre 2014/6/22 17:01
       Re: which ecu for use with ITBS ? ddgonzal 2014/6/22 19:53
         Re: which ecu for use with ITBS ? Anonymous 2014/6/22 22:36
       Re: which ecu for use with ITBS ? trb012 2014/6/22 23:00
         Re: which ecu for use with ITBS ? old-tin 2014/6/22 23:38
           Re: which ecu for use with ITBS ? trb012 2014/6/23 1:10
       Re: which ecu for use with ITBS ? lamb_daiquiri 2014/6/23 9:56
