Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc
From Cambria, California
Tech Wiki say GX double valve springs good to ~8,000 rpm. IMHO, if the OEM spec for the GX head was for double springs, I'd do what the book says. New springs, spring seats, spring caps and retainers are pretty easy to source. If you have a severe case of budgetosis, ask member PJZ if he has any good used bits in his inventory.
Posted on: 2014/7/18 23:01
Subject Poster Date
     Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Rallytwit 2014/6/30 4:28
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc benny 2014/6/30 8:17
         Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc datster 2014/6/30 12:16
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Rallytwit 2014/7/1 2:10
         Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc dattoman_1000 2014/7/1 12:02
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Otilram 2014/7/2 6:15
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Rallytwit 2014/7/9 4:54
         Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc grover 2014/7/13 17:42
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc 58custom 2014/7/17 20:53
         Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc OGREInc 2014/7/18 23:01
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Rallytwit 2014/7/25 6:17
       Re: Garage clean out: 73mm flat & 76 mm popup pistons + heads and misc Otilram 2014/7/25 21:08
