LHD hydraulic clutch hose question
What's the specification of the end of the flexible hose that goes into the clutch slave cylinder? I'm having troubles finding one, because what I pulled out is an M10x1 male with a convex flare, and all the ones I'm finding in local stores are M10x1 with an inverted/concave flare. But maybe what I have isn't a standard convex flare but an ISO bubble flare in a solid fitting. I've looked at the relevant datsun1200 tech wiki page, and at least one of the parts listed there is an inverted flare on the slave cylinder end (coz I found it at a local store.) In my particular situation I could just run a new hard line all the way to the clutch slave cylinder, but even then I need to know what the right flare geometry is.
Suggestions/ideas?
Thanks in advance.
Posted on: 2014/7/12 6:55
Subject Poster Date
     LHD hydraulic clutch hose question smellsofbikes 2014/7/12 6:55
       Re: LHD hydraulic clutch hose question ang94541 2014/7/13 8:47
       Re: LHD hydraulic clutch hose question smellsofbikes 2014/7/15 3:38
