Re: prop shaft axial play
From Melbourne AUS
i agree with you, its too long and most likely led to your gearbox failure
you need about 25mm of your slip-yoke hanging out the back of your gearbox when its all bolted up
good thing for you is that its a lot easier to make your prop shaft shorter than it is to make it longer!
Posted on: 2014/12/30 12:35
1973 B110 A12
Subject Poster Date
     prop shaft axial play thaifrog 2014/12/30 11:16
       Re: prop shaft axial play ANGE 2014/12/30 12:35
       Re: prop shaft axial play nismo1 2014/12/30 12:54
       Re: prop shaft axial play thaifrog 2014/12/30 14:32
